TwinTurbo.NET: Nissan 300ZX forum - Re: RHD Z's have the sensor on the left side turbos oil feed.
rmalik23
on February 12, 2013 at 1:03 AM
posted by LivinTheDream
on February 11, 2013 at 08:25 PM
My Z has the fitting you're talking about. I actually capped off the stock location since my AEM sender unit didn't fit. I ended up moving it to that located. It fit without issue.
Fitting to relocate oil pressure sensor
NextZ
11:51:03 02/11/13
Mine wasnt too close, have a pic? (n/m)
Z32TT-R
12:04:18 02/11/13
Its standard 1/8" BSPT size, look on mcmaster for fittings.
Lowfategg
12:15:18 02/11/13
Here's a pic of the brass fitting
NextZ
13:19:09 02/11/13
plumbing section of lowes has the same brass fittings
youngbloodz
15:42:36 02/11/13
Thanks. I was thinking of cutting the fitting threads
NextZ
15:57:42 02/11/13
Do you have to bottom out the threads for it to seal
ZXoltan
16:52:49 02/11/13
I tried sealant and not threading it all the way
NextZ
18:56:22 02/11/13
i used pipe sealant tape and havent had any leaks. I also
youngbloodz
00:02:03 02/12/13
NextZ
18:54:56 02/11/13
LivinTheDream
20:25:16 02/11/13
Re: RHD Z's have the sensor on the left side turbos oil feed. -
rmalik23
01:03:53 02/12/13
rmalik23
01:23:15 02/12/13
I'll have to check to see if the wire will reach (n/m)
NextZ
16:57:45 02/12/13
