TwinTurbo.NET: Nissan 300ZX forum - Rear Wheel Bearings
Subject Rear Wheel Bearings
Posted by Zeto32 on January 31, 2013 at 6:59 PM
  This message has been viewed 621 times.
Message Today I took the time to re-grease my rear wheel bearings along with brand new Timken seals. They were making quite a bit of noise so I made it a point to take them out and examine them to see if they needed replacing at all.
At first I had a lot of trouble removing the 36mm nut on the shaft. It was frozen and would not budge one bit. I don't think it has ever been touched since the day my car rolled off the assembly line. I sprayed it down with some WD-40 and used my trusty break bar. Still would not budge. So, I had to use a torch and heat it up. After a good 2 minutes or so of heat, it came right off.
I pull apart the assembly and look at the bearings to find out it was blackish-brown of what ever grease was in there. On the opposite side it was bone dry.
Image and video hosting by TinyPic
You could hear it rattling if you turned it by hand.
So I inspect all of the bearings to make sure they are smooth with no cracks, everything checked out OK.
Nice and cleaned up!
So, with some fresh new bearing grease, I apply it for both rear hubs and put it back on.
Now there is no more annoying noise after I get past 30MPH or so. Feels like it runs nice and smooth. Altogether, took me little over 4 hours to do.
