TwinTurbo.NET: Nissan 300ZX forum - Dual fuel pump install variations (upgrade factory wiring)
Subject Dual fuel pump install variations (upgrade factory wiring)
Posted by KongZTT GT28RS MD on January 19, 2013 at 8:58 AM
  This message has been viewed 331 times.
Message I know there are several members that have different variations of running dual fuel pumps.
I was surfing through search and ran across a few.. but figured I would post up and see what else is out there..
My original plan was to run twin Aeromotive stealth 340 pumps.. and a modified stock FPC (larger transistor and heat sink)
My turbos are GT28RS .. planning for around 700rwhp on boost alone w/ Q16 etc. and ~600rwhp on 93 pump.
Now looking at it.. I may just run a single Aeromotive stealth 340 since one should handle around that power level. However; I do plan on running n20 for some extra fun/numbers. (~100shot wet or direct port) If I go this route.. I should probably run dual pumps.
I have toyed with different ideas with wiring up dual pumps. Most likely will run both at the same time.. I know some run hobbs pressure switches etc.. but I think I will just run a toggle switch to activate the 2nd pump when I plan on spraying.
Let me know your ideas and plans! Pics are great too!
I would like to keep these dual IN-TANK fuel pumps if possible.
Thanks!
Kong
ps. This is for my 2+2 twinturbo conversion.. FWIW.. Plan on running TT ECU, TT EFI harness, and TT FPC wired directly to ECU for 3 speed operation.
~~~ Sig starts below
AIM:Shawn300zxTT
"-Any closeups on the nuts? - zboost(tx) 19:17:53
08/08/05
-Not really something you want to ask another man
about... (n/m) - LordZ 19:24:00 08/08/05"
Custom widebody
-2000 Nissan Altima SE (Daily driver)
-1990 Midnight blue 2+2 NA 5spd. (conversion soon :)
Gone..
-1997 Acura 2.2 CL, 5spd. Daily Driver.. (black ice victim
