TwinTurbo.NET: Nissan 300ZX forum - request some advice for Z1 shifter install
Subject request some advice for Z1 shifter install
Posted by surfer31337 on January 15, 2013 at 11:37 PM
  This message has been viewed 226 times.
Message Hi everyone, I got my solid shift mount installed, torqued down but then I ran out of daylight and it got too cold to continue working. This does give me the chance to regroup and ask about the shifter install. do you know any tips for installing the Z1 shifter? in particular, it has these thin washers (instead of bushings which were easier to hold in place) and i don't want to drop the washers into the abyss - can you suggest a method or "trick" to hold the washers onto the shifter while i line up the bolt? one other question, should i put any grease on the bolt which attaches the shifter to the linkage?
Thanks ! :-)
