TwinTurbo.NET: Nissan 300ZX forum - Get a compression and leak down test done. (n/m)
Summeronthechain (MN)
on October 24, 2012 at 2:40 PM
follow up on oil consumption on newly rebuilt engine
posted by tt_703
on October 24, 2012 at 01:53 PM
tt_703
13:53:31 10/24/12
Get a compression and leak down test done. (n/m) -
14:40:54 10/24/12
A compression test will tell you if there is a problem
MixManMash
14:47:44 10/24/12
I break in the engine similar to what you recommended, vary
tt_703
15:16:37 10/24/12
Assuming there are no visible leaks, I would have some tough
MixManMash
15:42:32 10/24/12
A compression test will "only" tell you if the compression
1badz32 (MN)
19:56:07 10/24/12
Isn't that what I wrote more or less? (n/m)
MixManMash
22:51:11 10/24/12
+1
Zvil
20:08:03 10/24/12
I hope you were topping it off within the 300 miles.
njz
16:23:06 10/24/12
From what you said , you only put 3.5 quarts on a TT engine?
tt_703
16:45:40 10/24/12
No I use 4-7/8 most guy on this site use 3.5 to 4
njz
16:51:55 10/24/12
The leak down test will determine what the next step is
TTZEDHEAD
18:30:03 10/24/12
What type of rebuild was performed? Rings only, bore and
CmyZ
00:01:54 10/25/12
Block was honed using stock pistons , new rings, main bearin
tt_703
01:55:46 10/25/12
are your cylinders round?
aliaZ
07:33:23 10/25/12
that is something I want to know too, this is my first
tt_703
08:51:52 10/25/12
that was your first mistake
aliaZ
13:18:32 10/25/12
+1. Who's idea was it to hone the cylinders and reuse the
stellar495
22:44:11 10/25/12
