TwinTurbo.NET: Nissan 300ZX forum - Solution? Get adjustable front Lower control arm for camber
RevTech
on September 21, 2012 at 3:19 PM
Be careful ! Many front upper adj. arms bend after few years
posted by RomChip200
on September 21, 2012 at 03:24 AM
SPL, Powertrix or whatever aftermarket fuca's are all doomed for failure. This is the second time I will mention this, the correct way to control camber on the front axle of a Z32 is from an adjustable Lower control arm. Period.
RomChip200
03:24:53 09/21/12
All the front adj. arms (current design) are going to bend
RomChip200
03:40:34 09/21/12
Re: All the front adj. arms (current design) are going to bend
Rob260
05:51:14 09/21/12
Re: Re: All the front adj. arms (current design) are going to bend
Rob260
05:52:29 09/21/12
Re: Re: Re: All the front adj. arms (current design) are going to bend
RomChip200
07:54:48 09/21/12
Re: Re: Re: Re: All the front adj. arms (current design) are going to bend
Rob260
23:35:05 09/22/12
Rob260
00:52:20 09/23/12
SPL should have a new arm out that solves this issue. (n/m)
MixManMash
05:07:40 09/21/12
Re: SPL should have a new arm out that solves this issue.
Rob260
05:45:00 09/21/12
Negative. I think they had a set back (sort of), but Sean
evan_aggie
07:57:10 09/21/12
Yes I saw the prototype here at Zcon... QUALITY!
Piranha
08:18:51 09/21/12
Powertrix has fixed this problem as well.
rojoloco (VA Beach)
06:52:30 09/21/12
Re: Powertrix has fixed this problem as well.
Rob260
06:57:32 09/21/12
There are several factors to consider.
rojoloco (VA Beach)
00:30:26 09/22/12
Powertrix and knock-offs have exactly this bent problem ! (n/m)
RomChip200
07:39:41 09/21/12
eh...no they haven't (n/m)
aliaZ
08:59:24 09/21/12
Well, what did they do to avoid it ? (n/m)
RomChip200
09:27:41 09/21/12
I'm sorry but both designs look the same
RomChip200
09:31:56 09/21/12
Was that the amount extended?
njz
10:46:22 09/21/12
umm...I'm saying that Powertrix didn't fix the problem (n/m)
aliaZ
12:56:01 09/21/12
false (n/m)
Adam (NoVA)
17:58:46 09/21/12
Did yours fail? If so did you install to spec?
njz
08:11:45 09/21/12
Re: Did yours fail? If so did you install to spec?
RomChip200
09:02:03 09/21/12
Is that the actual length of your FUCA when removed?
njz
10:58:01 09/21/12
The 300 Degree kit can be used behind an Aftermarket UFCA
Gordo 93TT Daytona
10:01:34 09/21/12
I'm sorry I don't follow many of you
RomChip200
10:11:36 09/21/12
I was always felt uncomfortable when I had FUCAS and RUCAS
KA8
10:49:43 09/21/12
I Have the newest Stillen design so you're saying mine will
craigz96tt
09:54:36 09/21/12
Yes
Jayru
12:56:53 09/21/12
Solution? Get adjustable front Lower control arm for camber -
RevTech
15:19:39 09/21/12
Who still makes that? I see some GSP products, but that is
evan_aggie
15:37:10 09/21/12
Re: Who still makes that? I see some GSP products, but that is
Rob260
00:53:30 09/23/12
here
aliaZ
14:03:02 09/23/12
instead of expecting us to take your word for it
aliaZ
14:15:06 09/23/12
Re: instead of expecting us to take your word for it
Rob260
17:58:21 09/23/12
