TwinTurbo.NET: Nissan 300ZX forum - I use motor oil to lube the o-rings.
Subject I use motor oil to lube the o-rings.
Posted by Wright (Ca) on January 04, 2012 at 6:13 PM
  This message has been viewed 150 times.
In Reply To How does one do the closed loop test? posted by ChrisMedaris on January 04, 2012 at 03:47 PM
Message To test for leaks plug one end of the fuel rail and pressurize at the other end with air. I use a bike pump with a gauge and pressurize it to 65-70 psi and then push the whole fuel rail setup under water to look for leaks.
