TwinTurbo.NET: Nissan 300ZX forum - The oil pump is a positive displacement pump...
Subject The oil pump is a positive displacement pump...
Posted by Jim (Selin Design) on December 16, 2011 at 1:46 AM
  This message has been viewed 252 times.
In Reply To Re: Re: Opinions on EPR ported oil pump? posted by soulpwr on December 16, 2011 at 01:07 AM
Message so the flow rate is strictly dictated by the pump gear size and engine RPM. Restrictions on the outlet should just put additional power burden on the crankshaft. The only way downstream restriction can reduce the flow is through increased leakage between the gap where the pump gears mesh which I would expect to be relatively low. It's also possible a few horses could be freed up by reducing pumping losses... it would be interesting to see testing.
www.selindesign.net
