TwinTurbo.NET: Nissan 300ZX forum - A one piece SS clutch line is pretty easy
Subject A one piece SS clutch line is pretty easy
Posted by Joe@ZSpeedperformance on August 14, 2011 at 4:20 PM
  This message has been viewed 563 times.
In Reply To Z1 sells the clutch damper line fitting elimination... posted by Coldfusown on August 14, 2011 at 04:04 PM
Message The system is not hard to bleed once you have the pedal adjusted correctly, A mis adjusted pedal/Master cyl rod will make it a PITA. If you have to bleed the line more than 5 times you are either not doing it right or something is out of adjustment.
www.Zspeedperformance.com
“Better to remain silent and be thought a fool than to speak out and remove all doubt.”
