TwinTurbo.NET: Nissan 300ZX forum - Some input and advice
Subject Some input and advice
Posted by ZXRider on July 17, 2011 at 4:08 AM
  This message has been viewed 325 times.
In Reply To Light engine rebuild... more of a refresher. posted by PiotrC70 on July 17, 2011 at 01:11 AM
Message answers to your questions:
1) Buy new OEM head bolts. You cannot re-use your original head bolts since the bolts stretch. Thee OEM bolts are sufficient enough unless you are going for some big HP numbers. Although the ARP bolts are nice since you can re-use them, how many times do you plan on having the cylinder heads off?
2) Rebuilding the heads is not a DIY for everyone. I recommend letting the more experienced individuals deal with that. Getting a cylinder head rebuild at a shop should not be that expensive. I paid $120 per cylinder head. I had the shop install the Viton valve seals instead of the OEM seals.
If you really want to rebuild your engine, just install new rings and bearings and be done with it. You can get the bearing grades off the block/crankshaft and combined with new rings you will have a fresh new engine to go with. Just get the block honed and you should be good to go.
Whatever path you decide to go, make sure you set some goals and stick with them. If you start the project and keep adding/changing your goals you might end up never getting the car back together.
Buy Zama Posters Here
I have nightmares about that happening...I'd be the poor bastard you'd hear about on the news that gets killed by a softball-size chunk while spreading out my body over the hood and screaming "Nooo!" (Having a conversation about hail damage) - BradZ (FL) on March 25, 2005 at 9:56 PM
Tell your friend that you could take a dump, light it on fire and that would be hotter shit than his car. Probes suck, that's just all there is to it. - 300ZXpert (someday) on April 04, 2005 at 11:35 PM
P.S. You REALLY are on here at ALL hours! And I thought I was bad! :) - zmenon on August 16, 2005 at 3:06 AM
LOL...2+2 drivers should grow mullets..."Business in the front...party in the back" ;) - BradZ (FL) on November 29, 2005 at 4:45 PM
