TwinTurbo.NET: Nissan 300ZX forum - Advice given by Greg D with regard to upgraded cams &
Subject Advice given by Greg D with regard to upgraded cams &
Posted by Mr.Stacy on June 07, 2011 at 7:40 AM
  This message has been viewed 447 times.
In Reply To 700rwhp build thread? Think its time for one! posted by fireballzx on June 07, 2011 at 04:03 AM
Message breather mods below. This advice was given for the 400+ cams. I would assume the same holds true to a greater degree for 500 cams.
"The 400+ cams work better than stock cams, when the car does not have breather mods. With breather mods the 400+ cams do not seem to add power with the fixed cam timing settings. The 400+ cams come with the exhaust cams advanced 4 degree's, I find pulling this timing out with adjustable sprockets, allows these cams to offer reasonable gains when the set up has breather mods. If your going to run 400+ cams and breather mods, I highly recommend getting the late model BDE intake sprockets, and the Tomei or Jun adjustable Exhaust cam sprockets (Z1 now sells these). Dialing in these cams is key."
