TwinTurbo.NET: Nissan 300ZX forum - I'm having similar problems with mine.
MY3ZTT
on May 09, 2011 at 7:49 PM
Anyone else have issues with their Z1 58mm throttle bodies?
posted by zgene4
on May 09, 2011 at 03:31 PM
Mine won't close all the way for the last 3-4mm. I have to force them down closed or release the throttle hard enough so they close. If i ease into the throttle and let off easily, they will stick. Sucks.
zgene4
15:31:17 05/09/11
Hmm..So because you bought the TBs 2nd-hand..
ForceFedTT (SoCal)
16:50:38 05/09/11
Almost all known companies I know of warranties are NOT
Gennosuke
17:50:11 05/09/11
i have the problem on new tb but i did not bother going to
ztunerz
18:31:11 05/09/11
I had the same problems with them a few years ago.
Kandy Orange Z
16:58:54 05/09/11
Re: Anyone else have issues with their Z1 58mm throttle bodies?
90GoldZ
17:44:25 05/09/11
On your 60mm tb's, did you add material to the plenum like
Wright (Ca)
17:49:40 05/09/11
I did it like Ash did.
90GoldZ
18:05:52 05/09/11
Want to do another plenum for me? (n/m)
Wright (Ca)
18:57:32 05/09/11
Re: Want to do another plenum for me?
90GoldZ
19:23:39 05/09/11
I have spare plenums. I will modify the tb's myself. Just
Wright (Ca)
19:28:25 05/09/11
S2z
17:56:49 05/09/11
all of that is beyond my toolbox capability and should be
zgene4
18:22:48 05/09/11
Re: all of that is beyond my toolbox capability and should be
S2z
18:35:16 05/09/11
I'm not blaming anyone, you've missed the point of this
zgene4
18:44:31 05/09/11
90GoldZ
18:54:08 05/09/11
More than one person having the issue would indicate QCI (n/m)
ZiNnYc
20:22:02 05/09/11
I'm having similar problems with mine. -
MY3ZTT
19:49:55 05/09/11
Diddo ... adjust , tap shaft , adjust , tap tap tap tap ....
xteam300tt
21:43:58 05/09/11
I hate to hear that you are having issues with our Throttle
Dustin@Z1
11:28:16 05/10/11
Thanks for your reply. I did contact Z1 as my first
zgene4
21:17:53 05/10/11
The ones I put together....
BOOZTD 3
15:52:22 05/10/11
I could help you fix it
Spectrum (WI)
22:24:33 05/10/11
tried the loose screw centering method, no luck because
zgene4
10:00:44 05/11/11
no problem, if I cant figure it out
Spectrum (WI)
21:24:44 05/11/11
