TwinTurbo.NET: Nissan 300ZX forum - I'd install an inline fuel pressure gauge
Subject I'd install an inline fuel pressure gauge
Posted by aliaZ on May 09, 2011 at 11:55 AM
  This message has been viewed 241 times.
In Reply To Thanks, I'm going to check the PRVR today and then the FPR posted by Ziceman(East TN) on May 09, 2011 at 08:18 AM
Message sounds as if your fuel pressure is bleeding off.
When it is hot, try cycling the pump a few times, and then start. If it starts up fine once pressure is built up, you have an issue with fuel pressure bleeding off due either a bad regulator or check valve.
To cycle the pump, turn the ignition on and listen for the fuel pump. Once it stops, turn the ignition off for about ten seconds, and repeat.
