TwinTurbo.NET: Nissan 300ZX forum - did the engine blow with the 550's? j/w why the rebuild
nissansx
on April 05, 2011 at 11:02 AM
Mod debate...why not open it to the opinions here?
posted by Only1Z
on April 04, 2011 at 11:15 PM
i would do option 2 and get the piping later since it can be installed with engine in place
Only1Z
23:15:47 04/04/11
you don't NEED 2.5" intercooler piping with sport 700s
KongZTT GT28RS MD
23:19:01 04/04/11
Or do option one...
11:18:17 04/05/11
Just make sure you get the .64 a/r exhaust turbine housing
KongZTT GT28RS MD
23:21:03 04/04/11
Definitely .64 A/R...forgot to mention that. (n/m)
Only1Z
23:30:24 04/04/11
I have 700's is there an easy way to tell which housings
Rogy
11:27:23 04/05/11
its written on the part of the turbine facing the firewall.
Antihero
13:11:59 04/05/11
If i had to do it again i would do more supporting mods
volcomstone550
23:25:15 04/04/11
Wait till you see the new dyno charts of the sport700s
KongZTT GT28RS MD
23:34:09 04/04/11
Also.. the sp90 don't use the stock inlet pipes..
KongZTT GT28RS MD
23:37:30 04/04/11
FYI.. I'm not knockin the SP90's
KongZTT GT28RS MD
00:19:43 04/05/11
i want to see someone fit the new Borg warner EFR turbos
volcomstone550
01:41:23 04/05/11
planning to get some and try by the end of May on the EFR's (n/m)
Arkham_Z
02:44:29 04/05/11
the issue with those is >>
ztunerz
11:15:01 04/05/11
I'll have one to test fit in 2 weeks......probably looking
Arkham_Z
11:32:47 04/05/11
Huh ? (n/m)
ztunerz
13:20:04 04/05/11
Those can be bought with recirculate valves, boost solenoids
Wright (Ca)
13:56:05 04/05/11
Have all the math for the solenoids from Borg W but no clue
Arkham_Z
14:08:25 04/05/11
if i were going that route
Antihero
19:10:44 04/05/11
better stuff than AEM out there (n/m)
ZiNnYc
19:48:53 04/05/11
Talk to Greg he sent me dyno graphs of the 2.5" mod, it's
5280Z_nightstalker
02:32:18 04/05/11
Still can't believe ppl are making that much power
Jackie
12:34:21 04/05/11
Amazing yes but engine pull required for manifolds. (n/m)
Wright (Ca)
13:49:05 04/05/11
Mod list, AF and fuel on the 28R? (n/m)
ZiNnYc
14:45:46 04/05/11
And boost? (n/m)
Only1Z
19:02:55 04/05/11
Im in the same spot man.......gtx3071
TTZ2NV(TX)
05:16:19 04/05/11
huh? those should be the same externally as 3071's
FuerGrissa
06:26:04 04/05/11
GTX3071 requires a T3 housing
aliaZ
08:23:47 04/05/11
keep your turbos, go with 2.5" mods
zgene4
09:13:03 04/05/11
I disagree.. The GT28RS are a better choice..
KongZTT GT28RS MD
10:02:00 04/05/11
"Real world" spoolup characteristics?
ZXoltan
10:52:03 04/05/11
When I had the GT28R turbo setup..
KongZTT GT28RS MD
11:16:11 04/05/11
I too, disagree. It all depends on the driver's definition
zgene4
15:10:34 04/05/11
did the engine blow with the 550's? j/w why the rebuild -
nissansx
11:02:53 04/05/11
Option #1. Add Ash's intake plumbing as well. (n/m)
11:10:50 04/05/11
I would have to agree with this but get the V2 intake
5280Z_nightstalker
14:38:23 04/05/11
As stated in the e-mail you will be far better off with
ztunerz
11:11:17 04/05/11
I have to agree!! It better to have a motor running
fst300zx
11:48:39 04/05/11
Atleast if you get bigger turbos.. you can upgrade the
KongZTT GT28RS MD
12:13:31 04/05/11
well I was relating more to his Q, Big turbos no piping
fst300zx
12:29:09 04/05/11
depends on the long term plan.
Antihero
12:51:00 04/05/11
do less of a motor build ..take the cash get chicks and blow
The Devils Z
16:46:17 04/05/11
Re: do less of a motor build ..take the cash get chicks and blow
supermario680
16:50:31 04/05/11
Breathing mods. Period.
CoHPhasor
18:40:59 04/05/11
