TwinTurbo.NET: Nissan 300ZX forum - 2nd I also don't think a 3/8ish fuel rail at 60+psi
Subject 2nd I also don't think a 3/8ish fuel rail at 60+psi
Posted by FuerGrissa on March 24, 2011 at 1:20 AM
  This message has been viewed 212 times.
In Reply To how is that possible? posted by aliaZ on March 24, 2011 at 01:10 AM
Message is flowing less than 2400 cc/min
unless I'm confused, too small of a diameter rail would manifest itself as too large of a pressure drop across it. If you run a pressure guage after the rail on the dyno you should see for sure if that's the problem.
BDE rails are 1/2in ID, I'm not sure what 300deg are, but either should be plenty for a 1krwhp build. the problem with 300deg would be sourcing large enough side feed injectors. SZ told me the other day that they were considering a side feed 1kcc/min setup for the blue beast.
