TwinTurbo.NET: Nissan 300ZX forum - A leak down would be more precise.. but a compression
Subject A leak down would be more precise.. but a compression
Posted by KongZTT GT28RS MD on March 23, 2011 at 4:53 PM
  This message has been viewed 121 times.
In Reply To It's listed in the Tech section. posted by Draker (Eugene, OR) on March 23, 2011 at 04:12 PM
Message test will be quite a bit faster.. It will atleast show if its a head gasket etc.. and point you in the right direction.
You can also get a radiator pressure tester kit and test the coolant system..
I believe the compression test numbers for a TT somewhere around 174psi with a minimum of 120ish?
You can also pull the plugs and read them.. that way you can single down which cylinder is the culprit.
However; you will be able to figure that out when compression testing.
_________________________________________________________________________
~~~ Sig starts below ~~~
MySpace for those who have em'
AIM:Shawn300zxTT
-1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car!
