TwinTurbo.NET: Nissan 300ZX forum - Pressure differential = your friend when flow testing air
Subject Pressure differential = your friend when flow testing air
Posted by LitlElvis on February 28, 2011 at 4:42 PM
  This message has been viewed 427 times.
In Reply To All in a day's work. :) AshSPEC Turbo Inlet Pipes >>>> posted by Ash's Z on February 28, 2011 at 03:54 PM
Message A differential of pressure (dP) is why air always flows from a high pressure area to a low pressure area. The turbo doesn't draw the air in, it merely creates a low pressure area and the prevailing barometric pressure is what forces the air to flow towards the turbo. The problem with the turbo inlet is you don't really want a large dP because it directly affects density and so a larger, more efficient duct is the only way to get closer to being the same as running no inlet duct at all. This isn't exactly a new concept.
Nice job with the inlets, I'm sure they'll do just what you claim they will... as long as they're more efficient than the stock ones are.
