TwinTurbo.NET: Nissan 300ZX forum - and try to use Shrink Tube instead of electrical tape (n/m)
TeddyZ(SFC)
on February 12, 2011 at 10:23 AM
soldering is an almost permanent bond..
posted by TeddyZ(SFC)
on February 12, 2011 at 09:55 AM
What's the stigma with crimping wiring connections?
J_Wright
09:52:09 02/12/11
TeddyZ(SFC)
09:55:07 02/12/11
and try to use Shrink Tube instead of electrical tape (n/m) -
TeddyZ(SFC)
10:23:02 02/12/11
2nd, I use heat shrink over the sodder joint then electrical
whip
11:08:01 02/12/11
solder (n/m)
whip
11:10:23 02/12/11
Better conductivity and normally the wire will break before
ShakaShaun(Denver)
09:58:47 02/12/11
Always solder if you can (n/m)
collegeboy
10:01:02 02/12/11
Crimping = Long-term corrosion = failure
cherryz
10:18:41 02/12/11
I have seen pretty bad solder joints in my days>>
Spectrum (WI)
10:50:15 02/12/11
Do whatever is most convenient for you
jkeyser14
11:20:50 02/12/11
Only other point to add to the posts below -- very
jzack
11:50:44 02/12/11
for connections in high vibration environments
Tektrader69
15:53:27 02/12/11
Solder if you can. Crimp if you can't solder or just want
DVDBURN (MD)
17:21:36 02/12/11
Your sig says it all
CoHPhasor
17:56:54 02/12/11
Crimp
freak152000
23:33:14 02/12/11
That's cost related, not quality related.
09:08:23 02/13/11
Re: That's cost related, not quality related.
freak152000
11:24:10 02/13/11
Yes, it's definitely overkill, but I never have to worry
13:47:46 02/13/11
