TwinTurbo.NET: Nissan 300ZX forum - The hot wire maf sensor determines mass of air not velocity
Subject The hot wire maf sensor determines mass of air not velocity
Posted by fcz32 on January 23, 2011 at 1:44 PM
  This message has been viewed 162 times.
In Reply To Q: does air temperature affect MAF voltage or is it just posted by The Devils Z on January 23, 2011 at 10:39 AM
Message It does so by converting the current the wire uses to stay at a certain temperature into a voltage the ecu can read. The current needed to stay at a certain temperature is directly proportional to the mass of air passing through it. Its proportional but variation in air density (due to air temp or air pressure) would change the reading. So to get an accurate reading, an intake air temp sensor is also necessary.
But to answer your question, yes both affect it, although air velocity is in no way calculated or sensed by the maf sensor. air velocity simply affects the mass which is the parameter being detected by the MAF sensor.
