TwinTurbo.NET: Nissan 300ZX forum - Suspension upgrades typically run more than $1K...
Subject Suspension upgrades typically run more than $1K...
Posted by cherryz on January 22, 2011 at 8:13 PM
In Reply To What is the best suspension upgrade for an NA? posted by Cd_ny on January 22, 2011 at 12:21 PM
Message especially if you're lowering because then you need adjustable arms front/rear and adj tension rods (or can sub the 300degree camber kit up front).
Lowering requires the ability to set everything to proper caster/camber/toe so you track correctly and don't wear the tires off unevenly. So don't forget to include the cost for a decent installer who knows how to set things up properly for your intended use.
My Powertrix SS install with labor was around $2300.
