TwinTurbo.NET: Nissan 300ZX forum - Re: need some advice
Subject Re: need some advice
Posted by CmyZ on October 07, 2010 at 1:53 PM
  This message has been viewed 67 times.
In Reply To need some advice posted by Gustavo on October 06, 2010 at 08:35 PM
Message You can switch the harness with the engine in, here is what to do.
Pull the plenum, since you are doing injectors. Get inside the car and make sure you remove the shifter support, so it does not get damaged when you are lowering the cross member.
Lift the car, lower the cross member and get to it. This will allow the engine to drop a couple of inches for you to have access, it won't be easy, but I have done it. My preferred way is to pull the engine.
Naturally you will have to realign the car after. Good luck.
