TwinTurbo.NET: Nissan 300ZX forum - Hmmmm interesting could be fuel pump control unit
Subject Hmmmm interesting could be fuel pump control unit
Posted by John (MD) on October 01, 2010 at 1:02 PM
  This message has been viewed 99 times.
In Reply To 1st Dyno Pull - Need some professional opinions... posted by MAD_96TT(ATX) on September 30, 2010 at 09:50 PM
Message before mine went out I saw a noticeable drop in fuel pressure at only wot this happened for about a month and then the unit went out all together resulting in me getting a used one from bernie. This was also my daily driver as well.
Check fuel pressure and change the fuel filter if it has not been changed in the last 20,000 to 30,000 miles.
There is no way it is a boost leak as others have suggested unless you have a hose that is getting ready to come off between the air filter and turbo and even if you did have that the car would not run well at all.
Also ohm all the injectors as well just to be on the safe side it is very easy to do they should be between 10 and 14 ohm's I believe.
