TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: anybody running the JWT solid lifter cams ye
Subject Re: Re: Re: Re: anybody running the JWT solid lifter cams ye
Posted by Tech@EPR on September 18, 2010 at 4:26 PM
  This message has been viewed 192 times.
In Reply To Re: Re: Re: anybody running the JWT solid lifter cams yet? (n/m) posted by Tech@EPR on September 18, 2010 at 04:21 PM
Message The suggested springs jwt states def are not suited for 8000rpms. The HD springs are def required and highly suggested over the ones jwt suggests. The springs go into harmonic flutter and will not control the valve past 5500 rpm.
Anytime you go with a solid lifter/cam outfit spring pressure has to increase go control valve action and increased harmonics. I've tested both springs and jwt suggested spring is inferior.
Don't always go by manufactures suggestions. Put the book down.
