TwinTurbo.NET: Nissan 300ZX forum - To help with the wheel hop...
Subject To help with the wheel hop...
Posted by ZLover4Life on August 19, 2010 at 1:34 AM
  This message has been viewed 116 times.
In Reply To haha ouch, oh well you know you helped! posted by pearlzed(toronto) on August 19, 2010 at 12:02 AM
Message Specialty Z subframe spacers "pre-load the stock rubber bushings so the body does not float separately from the subframe. Stock, the body floats about an inch before the suspension does anything. [...]
One of the reasons Zs wheel hop is because the sub frame is mounted loosely causing the subframe to bounce up and down. Pre-loading the stock bushings results in much more responsive handling and also greatly reduces wheel hop."
"When you say this, will you be surprised if your arguments seem to move about instead of staying put? And will you accuse me of being Daedalus who makes them move, though you are yourself much more skillful than Daedalus and make them go around in a circle? Or do you not realize that our argument has moved around and come again to the same place? [...] Or do you not remember?" - Socrates
