TwinTurbo.NET: Nissan 300ZX forum - Irrelevant. temp sender, the 1-wire sensor next to..
CoHPhasor
on June 29, 2010 at 1:36 AM
Re: Replace temp sensors.
posted by lugerz
on June 28, 2010 at 10:01 AM
coolant temp sensor is ONLY for the dash gauge and does NOT effect the ECU.
Check the 2-wire coolant temp sensor on the hardpipe, even if you put a new one in, the connector might be dirty.
What damage can this cause?
lugerz
20:18:30 06/27/10
Did you disconnect the battery for 30 minutes during the
ChrisZTT(Sacto, CA)
20:36:17 06/27/10
there is no "it" to think anything when you change ECU
Antihero
15:41:54 06/28/10
You got the correct eprom for those injectors? (n/m)
Draker (Eugene, OR)
20:36:32 06/27/10
Re: What damage can this cause?
CmyZ
20:55:38 06/27/10
I imagine using ECU for 370's vs 555's would make you
CoHPhasor
21:29:13 06/27/10
lugerz
21:31:59 06/27/10
As mentioned by ChrisZTT w/out reset it might not have taken
CoHPhasor
22:02:09 06/27/10
Re: As mentioned by ChrisZTT w/out reset it might not have taken
lugerz
22:08:41 06/27/10
So it bogs down @ 75% throttle after 20 mins of driving?
CoHPhasor
22:14:27 06/27/10
Draker (Eugene, OR)
22:46:04 06/27/10
lugerz
10:01:25 06/28/10
Irrelevant. temp sender, the 1-wire sensor next to.. -
CoHPhasor
01:36:36 06/29/10
Re: Irrelevant. temp sender, the 1-wire sensor next to..
lugerz
14:46:56 06/29/10
