TwinTurbo.NET: Nissan 300ZX forum - You're not running enough timing should be at least
Subject You're not running enough timing should be at least
Posted by MikeH(Phoenix) on June 26, 2001 at 10:44 PM
  This message has been viewed 26 times.
In Reply To Dyno results - sort of anyway posted by StEaMyZ(ZtoyZ.NET©) on June 26, 2001 at 09:40 PM
Message 17 degrees. That is what mine showed.
Mike
Arizona'a most powerful 600HP 15 second Z
More powerful than a stock TT , slower than an NA
Dynoed 515 rwhp and 420 ft.lbs @ 16psi 89 degrees.
533 rwhp and 450 ft. lbs @19 psi and slipping clutch
and heat soaked motor , 85 degrees.
