TwinTurbo.NET: Nissan 300ZX forum - A common mistake engine builders make when building our
Subject A common mistake engine builders make when building our
Posted by ztunerz on March 07, 2010 at 10:59 AM
  This message has been viewed 242 times.
In Reply To To clarify on this... i bought a built long block from an posted by Jkova300z on March 07, 2010 at 02:11 AM
Message engines is that they d not follow the nissan specs, they use SBC engine building guidlines (loose engines = better). Our engines have a lot tighter tolerances compared to the old school engines that these guys are used to building. Common issues are
Piston to cly wall clearance
Ring gaps
The honing process (too rough a stone and the engine burns oil)
FYI not all cast blocks are the same. I believe our blocks are harder and don't wear easily so you have to hone them with a fine grit stone to prevent oil burning.
Harry
Formerly yellowzxtt
