TwinTurbo.NET: Nissan 300ZX forum - Throttle Position Sensor, TPS, on the driverside of plenum (n/m)
on January 29, 2010 at 8:57 AM
I thought idle speed is controlled by the ECU....?
posted by ZXoltan
on January 29, 2010 at 08:27 AM
base timing
ms300tt
20:12:23 01/28/10
Base timing should be @ 15 +- 2 for all years except...
20:26:09 01/28/10
Re: base timing
canyoncarver
05:56:13 01/29/10
ZXoltan
08:27:50 01/29/10
Throttle Position Sensor, TPS, on the driverside of plenum (n/m) -
08:57:02 01/29/10
are you saying idle is controlled by adjusting the tps ? (n/m)
ztunerz
17:22:01 01/29/10
no, but that's what tells the ECU the butterfly position (n/m)
21:17:30 01/29/10
i know however your reply suggested that is a good way to
ztunerz
00:28:46 01/30/10
I can see how that wording says that, ms300tt is correct
10:32:40 01/30/10
:) (n/m)
ztunerz
11:30:00 01/30/10
Re: I thought idle speed is controlled by the ECU....?
ms300tt
12:08:23 01/29/10
canyoncarver
11:35:52 01/30/10
Re: Re: base timing
ms300tt
12:06:25 01/29/10
