TwinTurbo.NET: Nissan 300ZX forum - Honda ECU's use a Barometric pressure sensor inside the ECU
marklar182
on January 22, 2010 at 3:30 PM
you didn't answer my question
posted by aliaZ
on January 22, 2010 at 12:46 PM
in conjunction with the MAP (I know this for sure), other companies may do
the same.
Performance Motorsports Research MAP Setup
pearlwhite94ttz
22:59:29 01/21/10
Forgot the link to the systems
pearlwhite94ttz
23:02:51 01/21/10
If you go Map, just get AEM UEGO. That's what I have, and
collegeboy
23:35:56 01/21/10
Hmm
pearlwhite94ttz
01:19:10 01/22/10
makes a lot more sense than a piggyback to me (n/m)
Antihero
08:46:43 01/22/10
Depends
aliaZ
09:03:57 01/22/10
Ordering Nistune today! Im excited :)
treese88
09:52:27 01/22/10
Does the AEM UEGO count as Standalone?
pearlwhite94ttz
10:47:51 01/22/10
I believe it all depends on the tuner
collegeboy
10:54:39 01/22/10
while i agree it could be time consuming...
Antihero
11:54:17 01/22/10
Sounds like you want a complex system...
Antihero
11:50:41 01/22/10
closed loop feedback at WOT is dangerous (n/m)
aliaZ
12:49:39 01/22/10
im not talking about driving that way all the time.
Antihero
13:20:41 01/22/10
and i say its a necesity,bc you should retune 4 every mod (n/m)
Antihero
13:24:05 01/22/10
Mine will only autotune a small amount on its own.
dogpile
14:30:56 01/22/10
AEM UEGO is just a wideband O2 kit, not a standalone ECU. (n/m)
sparkie
14:38:27 01/22/10
lol...that's what I was thinking too! (n/m)
Ashman2k2
17:46:17 01/22/10
www.mapecu.com (n/m)
aliaZ
08:48:35 01/22/10
Stay w/ factory MAS setup if yours is a street car.
sparkie
11:42:11 01/22/10
How does factory MAP setups compensate for weather changes?
aliaZ
11:54:27 01/22/10
Because it's factory tuned. (n/m)
sparkie
11:58:27 01/22/10
aliaZ
12:46:40 01/22/10
There is alot to be said with the 'factory tune'.
sparkie
13:35:49 01/22/10
barometric correction is what I was looking for, thanks (n/m)
aliaZ
16:24:49 01/22/10
when you learn to set up and tune a standalone ECU
sparkie
23:06:11 01/22/10
Honda ECU's use a Barometric pressure sensor inside the ECU -
marklar182
15:30:42 01/22/10
thanks (n/m)
aliaZ
16:25:52 01/22/10
Does your haltech have wb o2 closed loop auto tune? (n/m)
Antihero
11:55:44 01/22/10
I have it for closed loop for low end
sparkie
12:06:24 01/22/10
yeah, but you can generate a proper tune
Antihero
12:19:57 01/22/10
The auto tune feature in Haltech
sparkie
13:55:32 01/22/10
on the AEM you can use the feature to generate a tune
Antihero
14:06:57 01/22/10
Right, the Haltech auto-tune is primarily used as a
sparkie
14:16:32 01/22/10
MAP-ECU has an auto tune feature which uses the MAF
pearlwhite94ttz
12:37:05 01/23/10
Well, is this considered "street"?
pearlwhite94ttz
13:18:29 01/22/10
A track car does not have to care about
sparkie
14:04:18 01/22/10
Ah. Thanks for clearing that up!
pearlwhite94ttz
14:14:08 01/22/10
And my tuning will be done by
pearlwhite94ttz
13:12:15 01/22/10
If Greg is tuning your Z and you want a MAP, then
Piranha(PHX)
22:58:44 01/22/10
