TwinTurbo.NET: Nissan 300ZX forum - Re: New pump in. Hours later. Problem not solved. There is ...
Subject Re: New pump in. Hours later. Problem not solved. There is ...
Posted by WeissNicht on January 21, 2010 at 4:21 AM
  This message has been viewed 104 times.
In Reply To New pump in. Hours later. Problem not solved. There is ... posted by LivinTheDream on January 21, 2010 at 01:43 AM
Message Is your collantlevel Ok after it ran hot? I had an issue with the small cap on the side of the radiator (screwed in fro the top, used to let out air while filling the system). It had a little hole in it and cause of this may cooling system couldn“t hold pressure.
Did you pressurize the coolingsystem to see if there are any leaks?
Maybe you could change yout temp-sensor cause its broken and tells you wrong numbers...
