TwinTurbo.NET: Nissan 300ZX forum - Re: (FIxed) Valve Issues (Soft Valves?)
Subject Re: (FIxed) Valve Issues (Soft Valves?)
Posted by Tech@EPR on December 08, 2009 at 8:50 PM
  This message has been viewed 201 times.
In Reply To (FIxed) Valve Issues (Soft Valves?) posted by Eric(NJ) on December 08, 2009 at 02:47 PM
Message valve float. You are beating the valves into the seats. You'll need a valve job in the worst way and definitely replace any and all valves that look like that.
Check your springs spring rate at its install height and see where they come in at. Ensure its within specs. You may have to replace the seats if they have been beaten really bad.
Here are some ferrea valves from a customers engine I worked on a while back. Not enough valve spring kills engines.
