| the black compressor inlet pipe. it is clocked wrong even when outlet nozzel is clock to correct. also the stock black pipe is about 46mm diameter, will choke most gt28 and all 30s. you will want a 60 OD diameter inlet pipe for a 2871 and 3071. The compressor outlet will be a nozzel coupler type connection. stock is a triangle 3 bolt. Hey if you got the skill and tools im all for it. Its building a WG bracket that doesnt flex and clears when mounted and clocked right which is going to be a pain.
Formerly SpecNATT (Houston) |
