| Message |
:Q - Is there a need to purchase an injector driver? :A - NoI'd rather hear this from Matt then from you. There are a slew of High CC/Min fuel injectors that typically need fuel injector drivers for other applications (mustangs/camaros /corvettes). If we're using the same injectors, that I can only assume we will need a fuel injector driver. Also, the higher your fuel delivery, you will require substantially higher fuel pressure just to allow the injector to open and close properly.
Petz #3
