TwinTurbo.NET: Nissan 300ZX forum - mt system is fine with a 85 amp alternator w/o a light-cap
Subject mt system is fine with a 85 amp alternator w/o a light-cap
Posted by Roc on June 25, 2001 at 10:57 AM
  This message has been viewed 139 times.
In Reply To HO Alternator....225 big ass AMPS!!!!! posted by zeeeeeya on June 25, 2001 at 09:43 AM
Message : I just got this email from Ohio Generator...competition alt thats, hands down...best in the world..period!
: Anyone putting a big systemin their Z(over 1000watts min) should consider 1 of these
: Reply-to:
: From: "Ampman"
: To:
: Subject: FW: Your HO alternator request from AMPMAN
: Date: Mon, 25 Jun 2001 11:09:04 -0400
: Hello Mike,
We are sorry for any delay in getting this information to you. Each alternator form requires exating research to design the correct HO alternator for your car. Virtually ALL Ohio Generator High Output alternators are assembled and shipped within 24-72 hours upon order (unless custom finish is requested).
: Based on the form you submitted the HIGH OUTPUT alternator you need for your NISSAN 300zx is a OHIO GENERATOR model #7769-185
: This HIGH OUTPUT alternator is rated at approximately 225 (HOT RATED)amps ( Cold rating (in amperage) are last 3 numbers in model # above) and is of the very highest quality, designed for continuous heavy duty high-output. It comes with a 1 year factory warranty offered by Ohio Generator. Ohio Alternators are used by more car audio competitors than all other high output alternators combined !!!! Ampman Audio is their only Internet authorized source for quality, service and reliability !!! As with any "high-output alternator" replacement for a car, we recommend the use of a voltage meter to assist you in making sure your cars electrical system is always running smoothly. Please note that ANY HIGH OUTPUT ALTERNATOR is designed to deliver voltage/current to you cars STOCK electrical system. Our OHIO GEN alternators are shipped to you custom made with regulation and wire harnesses to match YOUR car. Voltage and current ouput at IDLE are regualtor for your cars stock electrical system for reasons of SAFETY.
: The below OHIO alternator is custom-made specifically for YOUR CAR & SYSTEM. The alternator includes: Alternator, Regulator, mounting brackets (if needed). IF YOU ARE NOT MECHANICALLY INCLINED WE HIGHLY RECOMMEND USING A SKILLED MECHANIC (WE DO NOT RECOMMEND DEALERSHIPS AS YOUR FIRST CHOICE). PLEASE READ BELOW ABOUT THE NATURE OF YOUR INSTALLATION AS WE DO NOT ACCEPT RETURNS OF ALTERNATORS (THEY ARE CUSTOM MADE) UNLESS DEFECTIVE.
: Your discounted cost , which includes shipping (in the continental USA) is:
: $594.00 (Please note there is a 10% re-stocking fee on returned alternators)
: For your vehicle-the below alterations/concerns MAY apply:
*RELATIVELY EASY INSTALL-MAY REQUIRE A FEW WASHERS AND MINOR BRACKET WORK (BRACKET SUPPLIED BY OG WTH ALT)
: *PLEASE UPGRADE BOTH (POS & GROUND)YOUR ALTERNATOR FEED WIRES TO #4 GAUGE WIRES. WE HIGHLY RECOMMEND USE OF A VOLTMETER WITH ANY HIGH OUTPUT ALTERNATOR ON A HIGH WATTAGE AUDIO SYSTEM.
: ..... Please contact us with any questions you may have, the alternator is ready for shipment at your request !!!!
Jared
