TwinTurbo.NET: Nissan 300ZX forum - High Nox is usually due to high Cylinder temp.
Subject High Nox is usually due to high Cylinder temp.
Posted by Spddracer on November 18, 2009 at 9:18 PM
  This message has been viewed 84 times.
In Reply To Does Alcohol make the car run Lean or Rich? i ask posted by Nostype2 on November 18, 2009 at 06:48 AM
Message Check the heat range of the plugs and gaps.
Check O2 sensor readings for rich biased readings causing the car to lean out increasing cylinder temps.
Car running hotter than normal will also increase cylinder temps. Check cooling system.
EGR deleted will make them higher also but mine passed without it a few years back when we still had Emission testing.
Coming soon!! Zspeedperformance.com
