TwinTurbo.NET: Nissan 300ZX forum - Anyone tap into an oil cooler line for an Oil Temp Gauge?
d_flore
on November 11, 2009 at 11:25 AM
Has anyone done this here on a Z? Is it recommended?
What fittings did you use?
Anyone tap into an oil cooler line for an Oil Temp Gauge? -
d_flore
11:25:20 11/11/09
Not the best location as oil only flows through those
zgene4
12:27:01 11/11/09
what about aftermarket oil coolers...check valve too ?
TTkeeper
13:38:06 11/11/09
Hmm I dont belive I have the valve you mentioned as I am
d_flore
14:09:48 11/11/09
The valve is inside the filter tree.
Guapo
14:13:15 11/11/09
^^ Thats a good one to use. (n/m)
toykoz32
14:29:48 11/11/09
Exactly, doesn't matter what cooler you're using, the OEM
zgene4
14:49:43 11/11/09
Well that looks pretty much perfect. Thank you (n/m)
d_flore
15:11:58 11/11/09
You wouldnt happen to know if a similar item is avialable
d_flore
15:44:10 11/11/09
You need a 1/8"PT brass T, a 1/8"PT to 1/8"BPT thread
zgene4
15:54:24 11/11/09
no
gt300zxtt
16:27:05 11/11/09
its in the oil tree (n/m)
ztunerz
18:44:48 11/11/09
I used an oil filter sandwich. Easy. (n/m)
Got Z?
15:18:13 11/11/09
I was going to do that but i worried about the filter
d_flore
15:42:58 11/11/09
mine doesn't hang too low. I have a greddy. (n/m)
SuparexTT
15:52:04 11/11/09
I used SPL's sandwich (NLA). Works fines. (n/m)
Got Z?
17:02:20 11/11/09
On the opposite side of the oil filter tree is a plug
JustinSCZ32
19:38:44 11/11/09
opposite side of block* (n/m)
JustinSCZ32
19:39:16 11/11/09
Do what? (n/m)
Multi_Read (MO)
20:26:30 11/11/09
I belive that is where my stock oil press sensor is due my
d_flore
20:42:48 11/11/09
Yea, im pretty sure that's why there is a port there.. (n/m)
JustinSCZ32
20:47:16 11/11/09
I am not clear on what you are saying. I dont think the
d_flore
22:04:00 11/11/09
just look on the other side of the block
JustinSCZ32
09:43:22 11/12/09
thank you (n/m)
d_flore
15:00:37 11/12/09
I put an oil temp sensor there and it doesn't work very well
Mongoose
20:26:23 11/12/09
I used a oil sandwich plate for my pressure and oil temp
john90zxtt(OH)
21:19:39 11/11/09
