TwinTurbo.NET: Nissan 300ZX forum - replace the vacuum check valve on your brake thingy. (n/m)
ni[X]it
on October 10, 2009 at 8:08 PM
I wish that was true, for me....
posted by Multi_Read (MO)
on October 10, 2009 at 08:06 PM
General complaint: stock brakes suck...
thumper300zx
17:21:54 10/10/09
What pads are you using? (n/m)
John@Z1
17:26:41 10/10/09
PBR Metal Master. (n/m)
thumper300zx
13:07:31 10/11/09
They always like they were not enough for the weight of the
induetime
17:36:40 10/10/09
That's because the SZ Baer 2 piece rotors actually wear
MixManMash
18:41:44 10/10/09
Mine feels like it stops very quickly...I love my
600ZXR
18:12:07 10/10/09
Master cylinder brace made difference on my stock setup.
SimaYi
19:00:46 10/10/09
Just installed MBC Brace...here's the difference...
thumper300zx
13:09:09 10/11/09
thats the main purpose.. not to brake harder, but easier
JustinSCZ32
05:13:32 10/12/09
Stainless lines, BMC brace, and ATE fluid will stop great
19:03:27 10/10/09
Multi_Read (MO)
20:06:40 10/10/09
replace the vacuum check valve on your brake thingy. (n/m) -
ni[X]it
20:08:05 10/10/09
Something is wrong then. With cool brakes, I could stop
20:20:33 10/10/09
FYI the Ultimates, or Green Stuff wouldn't fade nearly that
Ashman2k2
20:46:32 10/10/09
HP+ would be the Ultimates equivalent from Hawk, and
Guapo
22:22:41 10/10/09
Probably more like 6-7 laps of the 10 lap heat.
23:13:28 10/10/09
You have air in your system or your booster is broken. (n/m)
20:32:03 10/10/09
I'm certain it isn't air in my system. What's the best way
Multi_Read (MO)
22:54:45 10/10/09
2nd, mine is on garage floor right now
FuerGrissa
22:57:04 10/10/09
From the FSM:
240Z FeO2
23:04:26 10/10/09
Like that says^
zcar4me
02:59:22 10/11/09
I'll inspect the brake booster, but I have my doubts. Would
thumper300zx
13:13:03 10/11/09
Did first two tests as per FSM...checked fine. (n/m)
thumper300zx
11:47:31 10/12/09
It's in my profile...
thumper300zx
13:10:03 10/11/09
300° Brake Master Cylinder Brace? (n/m)
13:53:51 10/11/09
Put one in yesterday, which is actually why...
thumper300zx
15:24:01 10/11/09
Agree. Stock does suck, but I am very pleased with my
MAD_96TT(ATX)
19:07:02 10/10/09
They don't suck, however they could be bigger.
Ashman2k2
19:08:50 10/10/09
See profile -- maybe my pads do suck...
thumper300zx
13:14:23 10/11/09
flush the fluid. huge difference.
ni[X]it
20:05:30 10/10/09
Fluid was recently flushed AGAIN. 2nd time in two years.
thumper300zx
13:06:59 10/11/09
Are you bleeding the ABS unit? Did you try bench bleeding
20:34:13 10/11/09
I've bled the system four times...
thumper300zx
22:51:52 10/11/09
I've had a 1991tt and a 1993tt, the 1993 was far better...
icsamerica
08:17:53 10/11/09
