TwinTurbo.NET: Nissan 300ZX forum - On a side note regarding fuel octane & emissions...
Subject On a side note regarding fuel octane & emissions...
Posted by Bernie (NoVA) on July 21, 2009 at 3:12 PM
  This message has been viewed 147 times.
In Reply To PSA: Do not use race gas without a wideband posted by 91Z32TT on July 21, 2009 at 12:56 PM
Message You're better off running a LOWER rated fuel then a race gas for emissions testing.
If you are on the edge (or failed and need a retest)->
*check your 02 sensors for proper function, ohm test your injectors, do a power balance test.
*check for coolant leaks or bubbles (if the car is over heating it will effect test results)
run the tank low on fuel.
roll the timing back to ~13 (the spec is 15 +/- 2, some stations will check timing prior to testing)
fill w. a few gallons of 87oct
take emissions test.
when you pass top off the tank w. premium fuel (91 or 93 if you can get it) and reset timing to 15.
Bernie
