TwinTurbo.NET: Nissan 300ZX forum - Re: Anyone install their a/c system with the motor in?
Subject Re: Anyone install their a/c system with the motor in?
Posted by CmyZ on July 20, 2009 at 8:01 PM
  This message has been viewed 109 times.
In Reply To Anyone install their a/c system with the motor in? posted by DualZ (SF) on July 20, 2009 at 07:54 PM
Message You must use a USDM compressor.. And yes you can install the lines with the motor in. The TT lines have the recharge fittings near the end that goes to the firewall. The NA High pressure hose recharge fitting is near the passenger shock/ strut tower and the low pressure side recharge fitting for the NA is closer to the front passenger also. This should help you distinguish the min AC lines..
Yes get a brand new drier and perform a very good vacuum on the system, after you checked for no leaks and before recharging the system for R134A
