TwinTurbo.NET: Nissan 300ZX forum - Re: Is it a big problem when engine seals are leaking
Subject Re: Is it a big problem when engine seals are leaking
Posted by -Grimm- on July 20, 2009 at 7:44 PM
  This message has been viewed 63 times.
In Reply To Is it a big problem when engine seals are leaking posted by Adamo on July 20, 2009 at 03:24 PM
Message My front main seal was bad when i bought the car.
Replaced it, all the cam seals, and the rear seal (while doing clutch).
If youre concerned about it springing a leak again it shouldnt. Replace the PCV valves (remove pressure from the crank case) for peace of mine if it helps you.
It is a bit of work though. Alot of things need to be removed to get to it.
