TwinTurbo.NET: Nissan 300ZX forum - Street clutch > Drag strip with slicks.
Subject Street clutch > Drag strip with slicks.
Posted by Spddracer on May 19, 2009 at 8:03 PM
  This message has been viewed 175 times.
In Reply To 1200 Miles, 15 times down the strip=DXD Fail. :-( posted by Jason300zxTT on May 19, 2009 at 05:45 PM
Message If you are going to drag that much you need a clutch that can do that, that much, Esp with slicks.
Even thou feramic dissipates heat very well, A full face street clutch cannot always dissipate the heat good enough for the strip.
I would have never recommended that clutch model for that much racing with slicks.
It takes about 1400* to seize feramic=Excessive slipping.
flywheel will be fine, It is just on the surface.
Even thou this is not really a warrantable issue I will see what I can do for you since Bernie got the clutch thru me for you.
Get a hold of me, you need a different set-up for what you are doing.
Coming soon!! Zspeedperformance.com
