TwinTurbo.NET: Nissan 300ZX forum - Their brake fluid - thumbs up! I use it for track and street (n/m)
Arthur
on April 30, 2009 at 6:13 PM
Who has tried MOTUL Oils or products?
posted by DEVILS Z-Tech (CA)
on April 30, 2009 at 03:43 PM
DEVILS Z-Tech (CA)
15:43:28 04/30/09
I've used their brake fluid - no complaints w. it. (n/m)
15:46:13 04/30/09
Re: I've used their brake fluid - no complaints w. it.
DEVILS Z-Tech (CA)
15:53:55 04/30/09
Yep, good stuff. Just make sure you change fluid every 6 mo (n/m)
Guapo
16:00:40 04/30/09
Re: Yep, good stuff. Just make sure you change fluid every 6 mo
DEVILS Z-Tech (CA)
16:10:34 04/30/09
Motul 600 tends to pick up moisture fairly quickly.
Guapo
16:16:43 04/30/09
Actually all polyglycol based fluids are hydroscopic and
DEVILS Z-Tech (CA)
16:24:49 04/30/09
Actually, it's been so many years, I don't have any
Guapo
16:40:27 04/30/09
Re: Actually, it's been so many years, I don't have any
DEVILS Z-Tech (CA)
17:03:02 04/30/09
Yep. FWIW, I am way, way, way past due on changing mine
Guapo
17:10:16 04/30/09
x2 on the moisture.
MixManMash
02:08:11 05/01/09
Same, the 600 here. (n/m)
SeedyROM
15:54:19 04/30/09
yup, alternated with RBF 600 & ATE super blue
vorpalZ
17:49:56 04/30/09
Do they make 10W-30? (n/m)
Piranha(PHX)
15:49:38 04/30/09
Re: Do they make 10W-30?
DEVILS Z-Tech (CA)
16:01:42 04/30/09
never had the need, Mobil 1 is sitting on a shelf maybe
15:52:53 04/30/09
I use it on a religious basis 5W-30 8100 Econergy
bardabe
18:11:38 04/30/09
Their brake fluid - thumbs up! I use it for track and street (n/m) -
Arthur
18:13:38 04/30/09
Wow arthur you have been around here for a looong time
DEVILS Z-Tech (CA)
18:34:56 04/30/09
Yup, since day 1! :)
Arthur
18:46:36 04/30/09
Talked to their rep at the Z nationials this past Sunday.
bbug
19:31:43 04/30/09
300v is the only oil that's worth a try
zyoulater
19:43:27 04/30/09
Re: 300v is the only oil that's worth a try
DEVILS Z-Tech (CA)
20:32:38 04/30/09
300v is the racing oil for it's high-end line, the other
zyoulater
22:36:41 04/30/09
I've been using 300V 10-40, no complaints.
sandeep_Z
20:26:24 04/30/09
Re: Who has tried MOTUL Oils or products?
thejoneZ (Sacto, CA)
00:40:02 05/01/09
I use that on our Saab, never got a chance to use the old
Ashman2k2
21:27:04 05/01/09
redline 5w-30, motul 5.1 brake (n/m)
ZiNnYc
11:02:59 05/01/09
