TwinTurbo.NET: Nissan 300ZX forum - Oil pressure at idle is fine but it should go up a bit
Subject Oil pressure at idle is fine but it should go up a bit
Posted by pcproa on April 09, 2009 at 8:09 AM
  This message has been viewed 103 times.
In Reply To Video Link!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! posted by d_flore on April 09, 2009 at 12:08 AM
Message more when you rev it. Please visit the link over at 3ZC. It's a sticky in the Z32 Technical FAQ section
http://www.3zc.com/showthread.php?t=142710
It's a scan of the user manual showing the range of oil pressures that are normal.
The lines are the same pressures on the gauge between kg/cm2 and PSI, just that the points are labeled differently.
And do not drive your car on the 370cc injectors with those turbos. Wait until you get the 740cc. I know you'll be tempted to take it out when you put it all back together but resist the temptation. Your engine will sustain damage the first time you put your foot to the floor.
1990 Nissan 300ZX
1982 Datsun 200SX
Cardomain website
