| Message |
on a sport 700 car with supporting mods - mani's, 615's, smic's, dual pop, ecu, etc. but no other work to the heads. just the wild cams with hd valve springs and new lifters/valve stem seals. no porting or oversized valves. bottom end is good, heads have bad stem seals. i was planning to install the cams with aforementioned new vss/lifters/valve springs and have the heads cleaned/milled. maybe bde vtc gears also. will it have noticeable gains? or are the gains mainly from porting... thnx and any other thoughts welcomed.
