TwinTurbo.NET: Nissan 300ZX forum - FYI it's a bit of a project to replace one
spyhunterTT(nj)
on March 11, 2009 at 6:03 PM
Thanks to all for the information
posted by ttzcadet
on March 11, 2009 at 06:00 PM
It's welded on the sides of the frame rail and ties in the tension rods and sway bar brackets. Ensure that it's properly aligned in the correct position before welding.
Alex
Fixing a cracking lower radiator support with bracing?
ttzcadet
13:29:06 03/11/09
so did put an ad in the classifieds?
gt300zxtt
13:39:48 03/11/09
You should never jacked from the front core - even with
13:59:43 03/11/09
If you did tweak the front, Robo has a detailed
boost420
16:43:29 03/11/09
Ability to fix it is limited to how bad the damage is. (n/m)
16:50:13 03/11/09
True, I was going to add that, thanks (n/m)
boost420
17:13:03 03/11/09
Replace it...
BradZ (UF)
14:32:11 03/11/09
Sure...
16:59:08 03/11/09
Ok bad news
ttzcadet
18:07:22 03/11/09
Re: Ok bad news
ttzcadet
18:15:51 03/11/09
Nice! Coz was probably cheaper too. (n/m)
BradZ (UF)
18:26:45 03/11/09
ttzcadet
18:00:35 03/11/09
FYI it's a bit of a project to replace one -
spyhunterTT(nj)
18:03:48 03/11/09
It's not that bad...
BradZ (UF)
18:25:46 03/11/09
