TwinTurbo.NET: Nissan 300ZX forum - Is the fuel pump a pretty common
WillsCustoms
on February 24, 2009 at 6:38 PM
Fuel pump is easy to check. First off it makes a lot of
posted by MrPulldown
on February 24, 2009 at 06:22 PM
issue on those cars? Its got 136k miles on it. The motor has a new top end, but im sure its the original pump
Possible new Z owner, need info.
WillsCustoms
16:31:54 02/24/09
I've heard of people swaping turbos with motor in....
Multi_Read (MO)
16:45:03 02/24/09
It's possible. I helped VorpalZ do it. Passenger side was
MixManMash
16:48:44 02/24/09
I have pulled and replaced turbos w/out removing engine
600ZXR
17:13:50 02/24/09
2nd. Need that wrench! (n/m)
MixManMash
17:20:41 02/24/09
Please expound on the "modified 13mm wrench." What are the
davidztt
20:42:47 02/24/09
buy cheap Chinese made 13mm wrench
vorpalZ
20:49:15 02/24/09
Thanks. Could I just go buy a "stubby" wrench or would that
davidztt
20:59:19 02/24/09
I just used a 6 point Craftsman combination wrench cut
600ZXR
21:02:53 02/24/09
2nd on pulling the engine being better than the idea of
TT XTZ
17:24:59 02/24/09
Local Nissan mechanic routinely replaces turbos without
vorpalZ
20:41:17 02/24/09
For what it's worth, I have not met a Nissan mechanic who
davidztt
21:11:30 02/24/09
Just had mine replaced a year ago with the engine in. (n/m)
huey24nissan(NC)
17:11:14 02/24/09
Turbos
WillsCustoms
17:27:46 02/24/09
No, but then you would have to drop the front crossmember to
MixManMash
19:10:37 02/24/09
No you don't
Crazy Greek
20:57:27 02/24/09
Must have had to angle that motor and trans to get it out?
MixManMash
22:44:29 02/24/09
Use an adjustable engine sling. (n/m)
Crazy Greek
03:07:54 02/25/09
MrPulldown
18:22:49 02/24/09
Is the fuel pump a pretty common -
WillsCustoms
18:38:52 02/24/09
Pull the fuel line right after the fuel filter.
TriniTT
21:50:50 02/24/09
I would do as TriniTT said and on top of that before you
5280Z_nightstalker
23:07:21 02/24/09
