| Message |
McMaster-Carr! It used to be .85/foot, now it's .94/foot. This is their SAE 30R7 hose, which is rated for a max pressure of 50psi. In my experience this is absolutely fine for the NA. I've been running it for the last two years. If you're using the hose in a TT application (43psi + plus boost), you may want to step up to the higher pressure hose (SAE 30R3) which is rated for up to 300psi (about the same outside dimension, but much less flexible). [ http://www.mcmaster.com/#54605k33/=k6q6c ]
-Brad '92 Z32 2+2 RACE CAR '91 MX83 1JZ grandma car ________________________ MY OPINIONS: -It's just a car. -Cars were meant to be driven. -You might as well call it the "S32" instead of the Z32, because they're basically just as attainable, old and molested as most 240SXs at this point. "You brad are just a car owner who only cares about yourself and not a true enthusiast..." - Spongerider :) on March 07, 2008 at 6:01 PM "Unless it has a vagina, its just a car." - Kenny on January 18, 2008 at 9:57 AM "Why upgrade a car if you don't take it out and beat up on it every now and then?" - fourZero on October 11, 2007 at 1:37 PM "...when i've been in florida, people drive crazy, dangerous, and fast." - ARA300ZX on January 10, 2007 at 12:06 PM "They turn their head because the 2+2 is sooo long." - ZJeweler(ssm300z) on July 13, 2006 at 4:43 PM "The Z was meant for the track, not the dragstrip." - Moxie on May 01, 2006 at 3:03 PM |
