TwinTurbo.NET: Nissan 300ZX forum - any fluid in clutch master? sound like it is low.
Subject any fluid in clutch master? sound like it is low.
Posted by toyluvr on June 13, 2001 at 5:56 PM
  This message has been viewed 21 times.
In Reply To Posted to tech forum too- can't shift when car warm. Help! posted by John P. on June 13, 2001 at 05:46 PM
Message You likely have a leaking slave and have lost enough fluid that you dont get enough travel when the car is hot to release.
Top up the fluid and pump up the pedal. If that works you are partway home.
you will need to find if the slave is leaking, if yes replace it and and flush and bleed the system.
