TwinTurbo.NET: Nissan 300ZX forum - injector clip question ... been using search.....not 100%
Subject injector clip question ... been using search.....not 100%
Posted by The Devils Z on April 05, 2008 at 10:29 PM
  This message has been viewed 329 times.
Message sure on the answer....took care of my boost leak ( fuel rail o-ring ) put the border fuel rail and 850cc injectors / plenum all back on .. realized afterwards after start up cylinder #6 injector clip wire broken .. so I had these ling around for 740cc injectors --
-but they will not work unless I pull the injectors out and massage the sides .. I am not looking to pull it all apart again ..
will the early style injector clip seen here
work with the 850cc injector ? it looks like it will ...
the injectors clips I have now are different than both of these pics ( thanks Z1 for the pics by the way ) ..the ones I have not are like the early style ( I am guesing ) but there is no retailing metal clip -- only a plastic tab that needs to be pushed in .. are these available if so .. pic and vendor ?
or do I have to use the early style connectors ?? THANKS
=============Sig begins here================
The Devils Z.com
The Devils Z Pic
666 rwhp dyno
The Demon Z pic (in progress)
View Me! Disclaimer : Not Safe For Work !
