I've found that much less pressure in the rear tires helps them to wear more uniformly, instead of mostly in the center. The fronts tend to wear the corners faster, so more psi helps the wear spread to the center. This is on 100% stock suspension w/ stock alignment settings. The rear Fusion Zri tires lasted ~20k and the fronts are still good at 25k at those psi settings w/ heavy street use.
